ArcGIS.Desktop.Editing.Controls Namespace / TableControl Class / Select Method / Select(IEnumerable<Int64>,Boolean) Method
The row indexes or object ids to select.
Indicates that the ids are object ids, otherwise they are row indexes.
    Selects rows in the table. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void Select(
       IEnumerable<long> ids,
       bool idsAreObjectIds
    Public Overloads Sub Select( _
       ByVal ids As IEnumerable(Of Long), _
       ByVal idsAreObjectIds As Boolean _
    Parameters
    ids
    idsAreObjectIds
    Exceptions
    ExceptionDescription
    Requirements
    ArcGIS Pro version: 3.3 or higher.
