ArcGIS.Desktop.Mapping Namespace / RangeExtent Class
Members
    RangeExtent Class
    Represents an extent defined by a min and a max value.
    Object Model
    RangeExtent ClassRangeExtent Class
    Syntax
    Public Class RangeExtent
    public class RangeExtent
    Remarks
    RangeExtent contains two properties Min and Max which defines an extent. Either property can be set to null. When Min is null it means the range extent begins infinitely small and when Max is null this means it ends infinitely large. This is useful for example when setting the MapView.Range property to show all values smaller than a given number, all values larger than a given number or to just show all values.
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Mapping.RangeExtent
    Requirements
