ArcGIS.Desktop.Mapping Namespace / SliceBox Class
Properties Methods
    SliceBox Class Members
    The following tables list the members exposed by SliceBox.
    Public Constructors
     NameDescription
    Public ConstructorOverloaded.
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets the SliceBox's culling direction. This defines in which direction to cut away geometry.
    Public Property Gets or sets the SliceBox's depth.
    Public Property Gets or sets the SliceBox's height.
    Public PropertyIdentifier for the exploratory analysis object within its current MapView.
    The ID is only unique to the map view that it was added to. For this reason, the same instance should not be added to more than one MapView. Use the subclass's copy constructor for that.
    (Inherited from ArcGIS.Desktop.Mapping.ExploratoryAnalysis)
    Public Property The current MapView that this exploratory analysis object is in. (Inherited from ArcGIS.Desktop.Mapping.ExploratoryAnalysis)
    Public Property Gets or sets the SliceBox's width.
    Top
    Public Methods
     NameDescription
    Public Method Gets the SliceBox's Transform to query its position, heading, or pitch.
    Public MethodSets the SliceBox's Transform to update its position, heading, or pitch. Must be in the target map's ArcGIS.Core.Geometry.SpatialReference.
    Top
