ArcGIS.Desktop.Mapping Namespace / SliceSphere Class
Properties Methods
    SliceSphere Class Members
    The following tables list the members exposed by SliceSphere.
    Public Constructors
     NameDescription
    Public ConstructorOverloaded.
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets the SliceSphere's culling direction. This defines in which direction to cut away geometry.
    Public PropertyIdentifier for the exploratory analysis object within its current MapView.
    The ID is only unique to the map view that it was added to. For this reason, the same instance should not be added to more than one MapView. Use the subclass's copy constructor for that.
    (Inherited from ArcGIS.Desktop.Mapping.ExploratoryAnalysis)
    Public Property The current MapView that this exploratory analysis object is in. (Inherited from ArcGIS.Desktop.Mapping.ExploratoryAnalysis)
    Public Property Gets or sets the SliceSphere's radius.
    Top
    Public Methods
     NameDescription
    Public Method Gets the SliceSphere's Transform to query its position, heading, or pitch.
    Public MethodSets the SliceSphere's Transform to update its position, heading, or pitch. Must be in the target map's ArcGIS.Core.Geometry.SpatialReference.
    Top
