ArcGIS.Desktop.Mapping Namespace / LinkChartFeatureLayer Class / GetTypeName Method
Example
    GetTypeName Method (LinkChartFeatureLayer)
    Gets the object type name that the link chart feature layer represents. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetTypeName() As String
    public string GetTypeName()
    Return Value
    The object tye name.
    Exceptions
    ExceptionDescription
    Example
    Create a LinkChart from a subset of an existing LinkChart IDSet
      //var map = ...
      if (map.MapType != MapType.LinkChart)
        return;
      // find the KG layer
      //var kgLayer = map.GetLayersAsFlattenedList()
      //        .OfType<KnowledgeGraphLayer>().FirstOrDefault();
      // find the first LinkChartFeatureLayer in the KG layer
      var lcFeatureLayer = kgLayer.GetLayersAsFlattenedList().OfType<LinkChartFeatureLayer>().FirstOrDefault();
      if (lcFeatureLayer != null)
        return;
      await QueuedTask.Run(() =>
        // get the ID set of the KG layer
        var idSet = kgLayer.GetIDSet();
        // get the named object type in the KG that the LinkChartFeatureLayer represents
        var typeName = lcFeatureLayer.GetTypeName();
        // if there are items in the ID Set for this type
        if (idSet.Contains(typeName))
          // build a new ID set containing only these records
          var dict = idSet.ToOIDDictionary();
          var oids = dict[typeName];
          var newDict = new Dictionary<string, List<long>>();
          newDict.Add(typeName, oids);
          var newIDSet = KnowledgeGraphLayerIDSet.FromDictionary(kgLayer.GetDatastore(), newDict);
          // now create a new link chart using just this subset of records
          MapFactory.Instance.CreateLinkChart("subset LinkChart", kgLayer.GetDatastore(), newIDSet);
    Requirements
    ArcGIS Pro version: 3.3 or higher.
