var kg_layer = map.GetLayersAsFlattenedList().OfType<KnowledgeGraphLayer>().FirstOrDefault();
if (kg_layer == null)
return;
if (map.MapType == MapType.LinkChart)
// if map is of MapType.LinkChart then the first level
// children of the kg_layer are of type LinkChartFeatureLayer
var childLayers = kg_layer.Layers;
foreach (var childLayer in childLayers)
if (childLayer is LinkChartFeatureLayer lcFeatureLayer)
var isEntity = lcFeatureLayer.IsEntity;
var isRel = lcFeatureLayer.IsRelationship;
// TODO - continue processing
else if (map.MapType == MapType.Map)
// if map is of MapType.Map then the children of the
// kg_layer are the standard Featurelayer and StandAloneTable
var chidlren = kg_layer.GetMapMembersAsFlattenedList();
foreach (var child in chidlren)
if (child is FeatureLayer fl)
// TODO - process the feature layer
else if (child is StandaloneTable st)
// TODO - process the standalone table
