ArcGIS.Desktop.Core Namespace / IMetadata Interface / ExportMetadata Method / ExportMetadata(String,MDImportExportOption,MDExportRemovalOption,String) Method
Example
    Export metadata
    Syntax
    Parameters
    outputFilePath
    exportType
    removalOption
    styleSheetPath
    Return Value
    void
    Example
    Item: export the metadata of the currently selected item: ExportMetadata
      await QueuedTask.Run(() =>
        metadataItemExport.ExportMetadata(@"E:\Temp\OutputXML.xml", MDImportExportOption.esriCustomizedStyleSheet, MDExportRemovalOption.esriExportExactCopy, @"E:\StyleSheets\Export\MyExportStyleSheet.xslt");
        // Or export using the current metadata style
        metadataItemExport.ExportMetadata(@"E:\Temp\OutputXML.xml", MDImportExportOption.esriCurrentMetadataStyle, MDExportRemovalOption.esriExportExactCopy);
    Requirements
