ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraphExtensions Class / GetIsKnowledgeGraphDataset Method
The dataset to check
Example
    Gets whether the dataset is a knowledge graph dataset or not. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Shared Function GetIsKnowledgeGraphDataset( _
       ByVal dataSet As Dataset _
    ) As Boolean
    public static bool GetIsKnowledgeGraphDataset(
       Dataset dataSet
    Parameters
    dataSet
    Return Value
    Exceptions
    ExceptionDescription
    Example
    Is a dataset part of a Knowledge Graph
      var featureLyer = MapView.Active.Map.GetLayersAsFlattenedList()
                      .OfType<FeatureLayer>().FirstOrDefault();
      if (featureLyer == null)
        return;
      await QueuedTask.Run(() =>
        //Get the feature class
        var fc = featureLyer.GetFeatureClass();
        // is it part of a KnowledgeGraph?
        var isPartOfKG = fc.GetIsKnowledgeGraphDataset();
    Requirements
    ArcGIS Pro version: 3.3 or higher.
