ArcGIS.Core.Geometry Namespace / IGeometryEngine Interface / SnapMsToSpatialReference Method
The input geometry.
Example
    SnapMsToSpatialReference Method (IGeometryEngine)
    Snaps the M-values to the M-precision (1 / MScale) of the spatial reference associated with the input geometry.
    Syntax
    Function SnapMsToSpatialReference( _
       ByVal geometry As Geometry _
    ) As Geometry
    Geometry SnapMsToSpatialReference(
       Geometry geometry
    Parameters
    geometry
    The input geometry.
    Return Value
    The geometry with the M-values snapped to the precision of the spatial reference. If the geometry is empty or the spatial reference is null, then the input geometry is returned unchanged.
    Exceptions
    ExceptionDescription
    Geometry is null.
    This geometry is not M-Aware.
    The method is not implemeted for GeometryBag.
    Example
    Snap the M-values to the M-precision of the spatial reference - SnapMsToSpatialReference
      SpatialReference sr = SpatialReferences.WebMercator;  // precision = 1 / MScale = 0.0001
      // MapPoint
      MapPointBuilderEx pointBuilder = new(3, 4, sr)
        M = 5.00006
      MapPoint point = pointBuilder.ToGeometry();
      MapPoint outputPoint = GeometryEngine.Instance.SnapMsToSpatialReference(point) as MapPoint;
      // outputPoint.M = 5.0001
      // Multipoint
      MapPointBuilderEx mapPointBuilderEx = new(-3, -4, sr)
        M = -5.000007
      pointBuilder = mapPointBuilderEx;
      MapPoint point2 = pointBuilder.ToGeometry();
      Multipoint multipoint = MultipointBuilderEx.CreateMultipoint([point, point2], AttributeFlags.HasM, sr);
      Multipoint outputMultipoint = GeometryEngine.Instance.SnapMsToSpatialReference(multipoint) as Multipoint;
      // outputMultipoint.Points[0].M = 5.0001, outputMultipoint.Points[1].M = -5
      // Polyline
      string json = "{\"hasM\":true,\"paths\":[[[3,2,10.00065],[3,4,15.000325],[5,4,20],[5,2,15.000325],[3,2,10.00065]]],\"spatialReference\":{\"wkid\":3857}}";
      polyline = PolylineBuilderEx.FromJson(json);
      Polyline outputPolyline = GeometryEngine.Instance.SnapMsToSpatialReference(polyline) as Polyline;
      // The M-values for the vertices in outputPolyline are { 10.0007, 15.0003, 20, 15.0003, 10.0007 }
    Requirements
    ArcGIS Pro version: 3.3 or higher.
