ArcGIS.Desktop.Mapping Namespace / KnowledgeGraphLayerIDSet Class / NamedObjectTypeCount Property
Example
    NamedObjectTypeCount Property (KnowledgeGraphLayerIDSet)
    Gets the count of named object types in the ID set.
    Syntax
    public int NamedObjectTypeCount {get;}
    Public ReadOnly Property NamedObjectTypeCount As Integer
    Example
    Get the ID Set of a KG layer
            await QueuedTask.Run(() =>
      var idSet = kgLayer.GetIDSet();
      // is the set empty?
      var isEmpty = idSet.IsEmpty;
      // get the count of named object types
      var countNamedObjects = idSet.NamedObjectTypeCount;
      // does it contain the entity "Species";
      var contains = idSet.Contains("Species");
      // get the idSet as a dictionary of namedObjectType and oids
      var oidDict = idSet.ToOIDDictionary();
      var speciesOIDs = oidDict["Species"];
      // alternatively get the idSet as a dictionary of
      // namedObjectTypes and uuids
      var uuidDict = idSet.ToUIDDictionary();
      var speciesUuids = uuidDict["Species"];
    Requirements
    ArcGIS Pro version: 3.3 or higher.
