ArcGIS.Core.Data Namespace / UpdateCursor Class / MoveNext Method
    MoveNext Method (UpdateCursor)
    Advances to the next Row in this UpdateCursor. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function MoveNext() As Boolean
    public bool MoveNext()
    Return Value
    true if the cursor has successfully advanced to the next row; false if the cursor has passed the end of the collection.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Remarks
    The UpdateCursor can only advance sequentially forward. To move the cursor back to the beginning, you will have to reexecute the search to obtain a new row cursor. If MoveNext() returns true, a Row object is created. Even if this row (Current) is not otherwise needed, it should be properly disposed through a call to System.IDisposable.Dispose or with the use of a using statement.
    Requirements
    ArcGIS Pro version: 3.4 or higher.
