Parameters
- name
- The name to use for the description object
| Exception | Description |
| System.ArgumentException | name is invalid |
await QueuedTask.Run(() =>
using (var kg = GetKnowledgeGraph(url))
var entity_name = "PhoneCall";
var relate_name = "WhoCalledWho";
var entityDesc = new KnowledgeGraphEntityTypeDescription(entity_name);
var relateDesc = new KnowledgeGraphRelationshipTypeDescription(relate_name);
//Run the schema builder
try
SchemaBuilder sb = new(kg);
sb.Delete(entityDesc);
sb.Delete(relateDesc);
//Use the KnowledgeGraph extension method 'ApplySchemaEdits(...)'
//to refresh the Pro UI
if (!kg.ApplySchemaEdits(sb))
var err_msg = string.Join(",", sb.ErrorMessages.ToArray());
System.Diagnostics.Debug.WriteLine($"Entity/Relate Delete error: {err_msg}");
catch (Exception ex)
System.Diagnostics.Debug.WriteLine(ex.ToString());
