ArcGIS.Core.Data.DDL.Knowledge Namespace / KnowledgeGraphEntityTypeDescription Class / KnowledgeGraphEntityTypeDescription Constructor / KnowledgeGraphEntityTypeDescription Constructor(String,IEnumerable<KnowledgeGraphPropertyDescription>,ShapeDescription)
The name to use for the description object
The collection of properties for the description object
The description to use for the shape. The spatial reference must match the spatial reference of the knowledge graph being used with the SchemaBuilder.
Example
    Construct a KnowledgeGraphEntityTypeDescription with the given name, collection of property descriptions, and shape description. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    name
    propertyDescriptions
    shapeDescription
    Exceptions
    ExceptionDescription
    name is invalid
    Remarks
    The name will be used for a new entity type if the description object is used for purposes of creation. Otherwise, it will be used to identify an existing entity type if the description object is used for the purposes of modify or delete. The spatial reference of the shape description parameter must match the spatial reference of the knowledge graph being used with the ArcGIS.Core.Data.DDL.SchemaBuilder. See ArcGIS.Core.Data.Knowledge.KnowledgeGraph.GetSpatialReference.
    Note: An ObjectID and GlobalID property description will automatically be added to the description object within the ArcGIS.Core.Data.DDL.SchemaBuilder (if these property descriptions were not included in the input propertyDescriptions collection)
    Example
    Create Entity and Relationship Types with SchemaBuilder
            await QueuedTask.Run(() =>
      using (var kg = GetKnowledgeGraph(url))
        var entity_name = "PhoneCall";
        var relate_name = "WhoCalledWho";
        //Entity Fields
        var descs1 =
            new List<KnowledgeGraphPropertyDescription>();
        descs1.Add(
          new KnowledgeGraphPropertyDescription("PhoneOwner", FieldType.String));
        descs1.Add(
          new KnowledgeGraphPropertyDescription("PhoneNumber", FieldType.String));
        descs1.Add(
          new KnowledgeGraphPropertyDescription("LocationID", FieldType.BigInteger));
        descs1.Add(
          new KnowledgeGraphPropertyDescription("DateAndTime", FieldType.Date));
        //Relate Fields
        var descs2 =
        descs2.Add(
          new KnowledgeGraphPropertyDescription("Foo", FieldType.String));
        descs2.Add(
          new KnowledgeGraphPropertyDescription("Bar", FieldType.String));
        var includeShape = true;//change to false to omit the shape column
        var hasZ = false;
        var hasM = false;
        KnowledgeGraphEntityTypeDescription entityDesc = null;
        KnowledgeGraphRelationshipTypeDescription relateDesc = null;
        if (includeShape)
          var sr = kg.GetSpatialReference();
          var shp_desc = new ShapeDescription(GeometryType.Point, sr)
            HasM = hasM,
            HasZ = hasZ
          entityDesc = new KnowledgeGraphEntityTypeDescription(
            entity_name, descs1, shp_desc);
          relateDesc = new KnowledgeGraphRelationshipTypeDescription(
            relate_name, descs2, shp_desc);
        else
            entity_name, descs1);
            relate_name, descs2);
        //Run the schema builder
        try
          SchemaBuilder sb = new(kg);
          sb.Create(entityDesc);
          sb.Create(relateDesc);
          //Use the KnowledgeGraph extension method 'ApplySchemaEdits(...)'
          //to refresh the Pro UI
          if (!kg.ApplySchemaEdits(sb))
            var err_msg = string.Join(",", sb.ErrorMessages.ToArray());
            System.Diagnostics.Debug.WriteLine($"Entity/Relate Create error: {err_msg}");
        catch (Exception ex)
          System.Diagnostics.Debug.WriteLine(ex.ToString());
    Modify Entity and Relationship Type Schemas with SchemaBuilder
          var kvp_entity = kg.GetDataModel().GetEntityTypes()
               .First(r => r.Key == entity_name);
          var kvp_relate = kg.GetDataModel().GetRelationshipTypes()
                         .First(r => r.Key == relate_name);
          //Let's delete one field and add a new one from each
          //A field gets deleted implicitly if it is not included in the list of
          //fields - or "properties" in this case....so we will remove the last
          //property from the list
          var entity_props = kvp_entity.Value.GetProperties().Reverse().Skip(1).Reverse();
          var prop_descs = new List<KnowledgeGraphPropertyDescription>();
          foreach (var prop in entity_props)
            if (prop.FieldType == FieldType.Geometry)
              continue;//skip shape
            var prop_desc = new KnowledgeGraphPropertyDescription(prop);
            prop_descs.Add(prop_desc);
          //deal with shape - we need to keep it
          //SchemaBuilder deletes any field not included in the "modify" list
          ShapeDescription shape_desc = null;
          if (kvp_entity.Value.GetIsSpatial())
            var geom_def = kvp_entity.Value.GetShapeDefinition();
            var shape_name = kvp_entity.Value.GetShapeField();
            shape_desc = new ShapeDescription(
              shape_name, geom_def.geometryType, geom_def.sr);
          //add the new entity property
          prop_descs.Add(
            KnowledgeGraphPropertyDescription.CreateStringProperty("foo", 10));
          //make a description for the entity type - ok if shape_desc is null
          var entityDesc = new KnowledgeGraphEntityTypeDescription(
            entity_name, prop_descs, shape_desc);
          //Add the entity type description to the schema builder using 'Modify'
          sb.Modify(entityDesc);
          //Repeat for the relationship - assuming we have at least one custom attribute field
          //that can be deleted on our relationship schema...
          var rel_props = kvp_relate.Value.GetProperties().Reverse().Skip(1).Reverse();
          var rel_prop_descs = new List<KnowledgeGraphPropertyDescription>();
          foreach (var prop in rel_props)
            rel_prop_descs.Add(prop_desc);
          ShapeDescription shape_desc_rel = null;
          if (kvp_relate.Value.GetIsSpatial())
            var geom_def = kvp_relate.Value.GetShapeDefinition();
            var shape_name = kvp_relate.Value.GetShapeField();
            shape_desc_rel = new ShapeDescription(
          //add a new relationship property
          rel_prop_descs.Add(
            KnowledgeGraphPropertyDescription.CreateStringProperty("bar", 10));
          //make a description for the relationship type - ok if shape_desc is null
          var relDesc = new KnowledgeGraphRelationshipTypeDescription(
            relate_name, rel_prop_descs, shape_desc_rel);
          //Add the relationship type description to the schema builder using 'Modify'
          sb.Modify(relDesc);
          try
              System.Diagnostics.Debug.WriteLine($"Entity/Relate Modify error: {err_msg}");
    Requirements
    ArcGIS Pro version: 3.4 or higher.
