ArcGIS.Core.Data.DDL.Knowledge Namespace / KnowledgeGraphEntityTypeDescription Class / KnowledgeGraphEntityTypeDescription Constructor / KnowledgeGraphEntityTypeDescription Constructor(String,TableDefinition)
The name to use for the description object
The table definition to use for the description object
    Construct a KnowledgeGraphEntityTypeDescription with the given name and ArcGIS.Core.Data.TableDefinition. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function New( _
       ByVal name As String, _
       ByVal tableDefinition As TableDefinition _
    public KnowledgeGraphEntityTypeDescription(
       string name,
       TableDefinition tableDefinition
    Parameters
    name
    tableDefinition
    Exceptions
    ExceptionDescription
    name is invalid
    Remarks
    The name will be used for a new entity type if the description object is used for purposes of creation. Otherwise, it will be used to identify an existing entity type if the description object is used for the purposes of modify or delete.
    The fields of the table definition will be used to initialize the property description collection for the description object. If a FeatureClassDefinition is used then a shape definition property will also be added (to the description object). The spatial reference of any spatial column in the input definition must match the spatial reference of the knowledge graph being used with the ArcGIS.Core.Data.DDL.SchemaBuilder. See ArcGIS.Core.Data.Knowledge.KnowledgeGraph.GetSpatialReference.
    Note: A GlobalID property description will automatically be added to the description object within the ArcGIS.Core.Data.DDL.SchemaBuilder if a GlobalID was not included in the fields collection of the input TableDefinition.
    Requirements
    ArcGIS Pro version: 3.4 or higher.
