ArcGIS.Core.Geometry Namespace / IGeometryEngine Interface / QueryPoints Method / QueryPoints(Segment,SegmentExtensionType,IEnumerable<Double>,AsRatioOrLength) Method
The segment on which the returned point lies.
Specifies the extension method.
The distances along the curve or the extended curve at which the returned points lie.
Determines whether the distancesAlongCurve is a ratio of the segment length or a length from the start point.
    Constructs a readonly list of MapPoints at distances along the curve or the extended curve.
    Syntax
    Parameters
    segment
    extensionType
    distancesAlongCurve
    asRatioOrLength
    Return Value
    The points at the given distances along the curve or extended curve.
    Exceptions
    ExceptionDescription
    segmentis null.
    Spatial reference of segmentis an image coordinate system.
    distancesAlongCurve
    Remarks
    If the distance is less than the length of the curve, then the returned point is the point at that distance along the curve. If the distance is less than zero, or greater than the length of the curve, then the returned point is on the curve specified by the extension method. The distance may be specified as a fixed unit of measure or a ratio of the length of the curve.
    Requirements
    ArcGIS Pro version: 3.4 or higher.
