ArcGIS.Core.Data.Mapping Namespace / AnnotationFeatureClass Class / CreateRow Method
An ArcGIS.Core.Data.RowBuffer with the field values to be set for the new feature.
Example
    CreateRow Method (AnnotationFeatureClass)
    Creates a new annotation feature in the feature class with a system assigned object ID. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public new AnnotationFeature CreateRow(
       RowBuffer featureBuffer
    Public Shadows Function CreateRow( _
       ByVal featureBuffer As RowBuffer _
    ) As AnnotationFeature
    Parameters
    featureBuffer
    Return Value
    A populated AnnotationFeature.
    Exceptions
    ExceptionDescription
    The path length of the AnnotationFeatureClass must be less than 252 characters.
    featureBuffer is null.
    A geodatabase-related exception has occurred.
    Example
    Creating a new Annotation Feature in an Annotation FeatureClass using a RowBuffer
      Task CreatingAnAnnotationFeatureAsync(Geodatabase geodatabase) => QueuedTask.Run(() =>
        using (AnnotationFeatureClass annotationFeatureClass = geodatabase.OpenDataset<AnnotationFeatureClass>("Annotation // feature // class // name"))
        using (AnnotationFeatureClassDefinition annotationFeatureClassDefinition = annotationFeatureClass.GetDefinition())
        using (RowBuffer rowBuffer = annotationFeatureClass.CreateRowBuffer())
        using (AnnotationFeature annotationFeature = annotationFeatureClass.CreateRow(rowBuffer))
          annotationFeature.SetAnnotationClassID(0);
          annotationFeature.SetStatus(AnnotationStatus.Placed);
          // Get the annotation labels from the label collection
          IReadOnlyList<CIMLabelClass> labelClasses =
            annotationFeatureClassDefinition.GetLabelClassCollection();
          // Setup the symbol reference with the symbol id and the text symbol
          CIMSymbolReference cimSymbolReference = new CIMSymbolReference();
          cimSymbolReference.Symbol = labelClasses[0].TextSymbol.Symbol;
          cimSymbolReference.SymbolName = labelClasses[0].TextSymbol.SymbolName;
          // Setup the text graphic
          CIMTextGraphic cimTextGraphic = new CIMTextGraphic();
          cimTextGraphic.Text = "Charlotte, North Carolina";
          cimTextGraphic.Shape = new MapPointBuilderEx(new Coordinate2D(-80.843, 35.234), SpatialReferences.WGS84)
            .ToGeometry();
          cimTextGraphic.Symbol = cimSymbolReference;
          // Set the symbol reference on the graphic and store
          annotationFeature.SetGraphic(cimTextGraphic);
          annotationFeature.Store();
    Requirements
