ArcGIS.Core.Data.Mapping Namespace / DimensionFeatureClass Class / CreateRow Method
An ArcGIS.Core.Data.RowBuffer with the field values to be set for the new feature.
    CreateRow Method (DimensionFeatureClass)
    Creates a new dimension feature in the feature class with a system assigned object ID. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Shadows Function CreateRow( _
       ByVal featureBuffer As RowBuffer _
    ) As DimensionFeature
    public new DimensionFeature CreateRow(
       RowBuffer featureBuffer
    Parameters
    featureBuffer
    Return Value
    A populated DimensionFeature.
    Exceptions
    ExceptionDescription
    featureBuffer is null.
    A geodatabase-related exception has occurred.
    Requirements
