ArcGIS.Core.Data.Realtime Namespace / RealtimeRowSource Enumeration
Example Example
    Specifies the type of a RealtimeRow.
    Syntax
    Members
    MemberDescription
    EventDeleteThe RealtimeRow was created as a result of a Delete event.
    EventInsertThe RealtimeRow was created as a result of an Insert event.
    PreExistingThe RealtimeRow represents a database row that already existed when the query operation was executed.
    Example
    Search And Subscribe for Streaming Data
      // Note: call within QueuedTask.Run()
        //query filter can be null to search and retrieve all rows
        //true means recycling cursor
        using (var rc = streamLayer.SearchAndSubscribe(qfilter, true))
          //waiting for new features to be streamed
          //default is no cancellation
          while (rc.WaitForRowsAsync().Result)
            while (rc.MoveNext())
              using (var row = rc.Current)
                //determine the origin of the row event
                switch (row.GetRowSource())
                  case RealtimeRowSource.PreExisting:
                    //pre-existing row at the time of subscribe
                    continue;
                  case RealtimeRowSource.EventInsert:
                    //row was inserted after subscribe
                    continue;
                  case RealtimeRowSource.EventDelete:
                    //row was deleted after subscribe
                    continue;
        }//row cursor is disposed. row cursor is unsubscribed
        //....or....
        //Use the feature class instead of the layer
        using var rfc = streamLayer.GetFeatureClass();
        //non-recycling cursor - 2nd param "false"
        using (RealtimeCursor rc = rfc.SearchAndSubscribe(qfilter, false))
            //etc
    Search And Subscribe With Cancellation
        //Recycling cursor - 2nd param "true"
        //or streamLayer.Subscribe(qfilter, true) to just subscribe
          //auto-cancel after 20 seconds
          var cancel = new CancellationTokenSource(new TimeSpan(0, 0, 20));
          //catch TaskCanceledException
          try
            while (rc.WaitForRowsAsync(cancel.Token).Result)
              //check for row events
                using var row = rc.Current;
                //etc
          catch (TaskCanceledException)
            //Handle cancellation as needed
          cancel.Dispose();
    Subscribe to Streaming Data
      //Note: with feature class we can also use a System Task to subscribe and
      //process rows
        // or var rfc = realtimeDatastore.OpenTable(name) as RealtimeFeatureClass
        using RealtimeFeatureClass rfc = streamLayer.GetFeatureClass();
        //subscribe, pre-existing rows are not searched
        using RealtimeCursor rc = rfc.Subscribe(qfilter, false);
        SpatialQueryFilter spatialFilter = new SpatialQueryFilter();
                  //getting geometry from new events as they arrive
                  Polygon poly = ((RealtimeFeature)row).GetShape() as Polygon;
                  //using the geometry to select features from another feature layer
                  spatialFilter.FilterGeometry = poly;//project poly if needed...
                  featureLayer.Select(spatialFilter);
                  continue;
                default:
                  continue;
    Search Existing Data and Subscribe for Streaming Data
      //Note we can use System Task with the Realtime feature class
      //for subscribe
        using RealtimeCursor rc = rfc.SearchAndSubscribe(qfilter, false);
        //default is no cancellation - use await in async method
          //pre-existing rows will be retrieved that were searched
            using RealtimeRow row = rc.Current;
            var row_source = row.GetRowSource();
            switch (row_source)
                //TODO - handle deletes
                break;
                //TODO handle inserts
                break;
                //TODO handle pre-existing rows
                break;
    Search And Subscribe With Cancellation 2
        using RealtimeCursor rc = rfc.SearchAndSubscribe(qfilter, true);
        try
          // Use await in async method
              using RealtimeRow record = rc.Current;
              // Process the record
        cancel.Dispose();
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.Data.Realtime.RealtimeRowSource
    Requirements
