ArcGIS.Core.Data.Realtime Namespace / RealtimeDatastore Class / GetTableNames Method
Example
    GetTableNames Method (RealtimeDatastore)
    Gets the name of all the tables that exist in the currently opened realtime data store. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public IReadOnlyList<string> GetTableNames()
    Public Function GetTableNames() As IReadOnlyList(Of String)
    Return Value
    The name of all the tables that exist in the currently opened realtime data store.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Please make sure a valid data store has been opened first.
    The data store does not support this operation.
    Remarks
    For stream service there is always only one table per datastore.
    Example
    Connect to a real-time feature class from a real-time datastore
      var url = "https://geoeventsample1.esri.com:6443/arcgis/rest/services/AirportTraffics/StreamServer";
      await QueuedTask.Run(() =>
        var realtimeServiceConProp = new RealtimeServiceConnectionProperties(
                                       new Uri(url),
                                       RealtimeDatastoreType.StreamService
        using var realtimeDatastore = new RealtimeDatastore(realtimeServiceConProp);
        //A Realtime data store only contains **one** Realtime feature class (or table)
        var name = realtimeDatastore.GetTableNames().First();
        using (RealtimeFeatureClass realtimeFeatureClass = realtimeDatastore.OpenTable(name) as RealtimeFeatureClass)
          //feature class, by default, is not streaming (opposite of the stream layer)
          realtimeFeatureClass.StartStreaming();
          //TODO use the feature class
    Requirements
