Return Value
true if this table has a field containing track ids; otherwise, false.
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
If the table has a TrackID field, then you can renderer previous observations with different symbology and/or draw lines by connecting those observation locations.
Also refer to ArcGIS.Deskop.Mapping.StreamLayer.SetPreviousObservationsRenderer and ArcGIS.Deskop.Mapping.StreamLayer.SetTrackLinesRenderer for more details.
// Note: call within QueuedTask.Run()
using var rfc = streamLayer.GetFeatureClass();
using var rfc_def = rfc.GetDefinition();
if (rfc_def.HasTrackIDField())
//Track aware
using (var rfc = streamLayer.GetFeatureClass())
using (var rfc_def = rfc.GetDefinition())
var fld_name = rfc_def.GetTrackIDField();
