ArcGIS.Core.Data.Realtime Namespace / RealtimeTable Class / GetDefinition Method
    GetDefinition Method (RealtimeTable)
    Gets the RealtimeTableDefinition of this dataset. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public new RealtimeTableDefinition GetDefinition()
    Public Shadows Function GetDefinition() As RealtimeTableDefinition
    Return Value
    The RealtimeTableDefinition of this dataset.
    Exceptions
    ExceptionDescription
    This dataset does not have a valid definition.
    A geodatabase-related exception has occurred.
    Requirements
