ArcGIS.Core.Data.Realtime Namespace / RealtimeTable Class / GetFilterWhereClause Method
    GetFilterWhereClause Method (RealtimeTable)
    Gets the filter that is set to this table. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public string GetFilterWhereClause()
    Public Function GetFilterWhereClause() As String
    Return Value
    A string representing SQL where clause.
    Exceptions
    ExceptionDescription
    Requirements
