ArcGIS.Core.Data.Realtime Namespace / RealtimeTable Class / Subscribe Method
A null query filter will cause all rows that become available to be retrieved.
If set to true, all the entries in RealtimeCursor will reference the most current row returned by RealtimeCursor.Current. To ensure all the entries in RealtimeCursor remain unique, set useRecyclingCursor to false. The default is true.
    Subscribe Method (RealtimeTable)
    Subscribe to receive row events. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    queryFilter
    useRecyclingCursor
    Return Value
    A RealtimeCursor that encapsulates the retrieved rows, as well as provides facilities to wait for new row events.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Remarks
    This method is thread-safe and it can be called on any thread. If the cursor is disposed or in the process of being disposed when this method is called it will result in undefined behavior. As opposed to SearchAndSubscribe, this method does not perform a Search operation. As a consequence, the returned RealtimeCursor will only iterate over rows that became available immediately after the execution of this method. If no query filter is set, all rows that become available will be retrieved.
    Requirements
