ArcGIS.Core.Data.Realtime Namespace / RealtimeTableDefinition Class / HasTrackIDField Method
    HasTrackIDField Method (RealtimeTableDefinition)
    Gets a value indicating whether this table has a field whose values are used to group rows in tracks. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function HasTrackIDField() As Boolean
    public bool HasTrackIDField()
    Return Value
    true if this table has a field containing track ids; otherwise, false.
    Exceptions
    ExceptionDescription
    Requirements
