ArcGIS.Core.Data.Realtime Namespace / StreamServiceFeatureClassDefinition Class / GetRelatedFeatureServiceLayerURL Method
    GetRelatedFeatureServiceLayerURL Method (StreamServiceFeatureClassDefinition)
    Gets the URL of a feature service layer that related attribues for streamed features.
    Syntax
    Public Function GetRelatedFeatureServiceLayerURL() As Uri
    public Uri GetRelatedFeatureServiceLayerURL()
    Return Value
    Remarks
    The related feature service may contains geometry field. For example, you may be monitoring water level at stream gauges - in this case stream service can broadcast only attribues such as water level, but the location of those gauges and any other static attributes are stored within the related feature service.
    Another example could be monitoring airlines flight locations. In this case stream service broadcasts the lastest locations of each airlines, but some other information such as airplane make, model, capacity, ranges etc. can be retrieved from the related feature service layer.
    Requirements
