ArcGIS.Desktop.Core Namespace / CustomProjectItemContainer<T> Class / CreateItemPrototype Method
The name of the item
It's physical path
The type of the container
For internal use. This will be empty
    Provides a factory method for custom project item containers to create custom project items of its contained type.
    Syntax
    Public Overrides Function CreateItemPrototype( _
       ByVal name As String, _
       ByVal path As String, _
       ByVal containerType As String, _
       ByVal data As String _
    ) As Item
    public override Item CreateItemPrototype(
       string name,
       string path,
       string containerType,
       string data
    Parameters
    name
    path
    It's physical path
    containerType
    data
    Return Value
    The created custom project item
    Remarks
    Called by the base implementation of CreateItem. The parameters passed to the method match the information persisted via ProjectItemInfo via the CustomProjectItem GetInfo() call.
    Requirements
