ArcGIS.Desktop.Mapping Namespace / BaseCreationParams Class
Properties Methods
    BaseCreationParams Class Members
    The following tables list the members exposed by BaseCreationParams.
    Protected Constructors
     NameDescription
    Protected Constructor Default constructor.
    Top
    Public Properties
     NameDescription
    Public PropertyGets and sets the index of the MapMember in the map or group layer. MapMemberPosition must be set to MapMemberPosition.Index for this value to honored. If MapMemberPosition is set to MapMemberPosition.Index and this value is NOT set, then the behavior will revert to auto arrange.
    Public PropertyGets and sets the mapMember position. Specifies whether the mapMember should be auto positioned or be on the top or at the bottom. Default value is MapMemberPosition.AutoArrange.
    Top
    Protected Methods
     NameDescription
    Protected Internal Method Derived classes must call this method to explicitly set the auto-grouping behavior for the map member being created.
    Top
