//Note: Call within QueuedTask.Run()
//The fields in the datasource used for the report
//This uses a US Cities dataset
var listFields = new List<CIMReportField> {
//Grouping should be the first field
new CIMReportField{Name = "STATE_NAME", FieldOrder = 0, Group = true, SortInfo = FieldSortInfo.Desc}, //Group cities using STATES
new CIMReportField{Name = "CITY_NAME", FieldOrder = 1},
new CIMReportField{Name = "POP1990", FieldOrder = 2, },
//Definition query to use for the data source
var defQuery = "STATE_NAME LIKE 'C%'";
//Define the Datasource
var reportDataSource = new ReportDataSource(featureLayer, defQuery, listFields);
//The CIMPage defintion - page size, units, etc
var cimReportPage = new CIMPage
Height = 11,
StretchElements = false,
Width = 6.5,
ShowRulers = true,
ShowGuides = true,
Margin = new CIMMargin { Bottom = 1, Left = 1, Right = 1, Top = 1 },
Units = LinearUnit.Inches
//Report template
var reportTemplates = await ReportTemplateManager.GetTemplatesAsync();
var reportTemplate = reportTemplates.Where(r => r.Name == "Attribute List with Grouping").First();
//Report Styling
var reportStyles = await ReportStylingManager.GetStylingsAsync();
var reportStyle = reportStyles.Where(s => s == "Cool Tones").First();
//Field Statistics
var fieldStatisticsList = new List<ReportFieldStatistic> {
new ReportFieldStatistic{ Field = "POP1990", Statistic = FieldStatisticsFlag.Sum}
//Note: NoStatistics option for FieldStatisticsFlag is not supported.
var newReport = ReportFactory.Instance.CreateReport("USAReport", reportDataSource, cimReportPage, fieldStatisticsList, reportTemplate, reportStyle);
System.Object
ArcGIS.Desktop.Reports.ReportDataSource
