Public Class FeatureLayerCreationParams Inherits LayerCreationParams
public class FeatureLayerCreationParams : LayerCreationParams
var flyrCreatnParam = new FeatureLayerCreationParams(new Uri(@"c:\data\world.gdb\cities"))
Name = "World Cities",
IsVisible = false,
MinimumScale = 1000000,
MaximumScale = 5000,
DefinitionQuery = new DefinitionQuery(whereClause: "Population > 100000", name: "More than 100k"),
RendererDefinition = new SimpleRendererDefinition()
SymbolTemplate = SymbolFactory.Instance.ConstructPointSymbol(
CIMColor.CreateRGBColor(255, 0, 0), 8, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
//Note: Needs QueuedTask to run
var featureLayerWithParams = LayerFactory.Instance.CreateLayer<FeatureLayer>(flyrCreatnParam, map);
//The catalog path of the feature layer to add to the map
var featureClassUriVisibility = new Uri(@"C:\Data\Admin\AdminData.gdb\USA\cities");
//Define the Feature Layer's parameters.
var layerParamsVisibility = new FeatureLayerCreationParams(featureClassUriVisibility)
//Set visibility
IsVisible = false,
//Create the layer with the feature layer parameters and add it to the active map
var createdFC = LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParamsVisibility, MapView.Active.Map);
//Define a simple renderer to draw the Point US Cities feature class.
var simpleRender = new SimpleRendererDefinition
SymbolTemplate = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.RedRGB, 4.0, SimpleMarkerStyle.Circle).MakeSymbolReference()
var featureClassUri = new Uri(@"C:\Data\Admin\AdminData.gdb\USA\cities");
var layerParams = new FeatureLayerCreationParams(featureClassUri)
//Set visibility
IsVisible = true,
//Set Renderer
RendererDefinition = simpleRender,
var createdFCWithRenderer = LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParams, MapView.Active.Map);
var featureClassUriDefinition = new Uri(@"C:\Data\Admin\AdminData.gdb\USA\cities");
var layerParamsQueryDefn = new FeatureLayerCreationParams(featureClassUriDefinition)
IsVisible = true,
DefinitionQuery = new DefinitionQuery(whereClause: "STATE_NAME = 'California'", name: "CACities")
var createdFCWithQueryDefn = LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParamsQueryDefn, MapView.Active.Map);
System.Object
ArcGIS.Desktop.Mapping.BaseCreationParams
ArcGIS.Desktop.Mapping.MapMemberCreationParams
ArcGIS.Desktop.Mapping.LayerCreationParams
ArcGIS.Desktop.Mapping.FeatureLayerCreationParams
