ArcGIS.Desktop.Mapping Namespace / FilterDefinition Class / ID Property
Example
    ID Property (FilterDefinition)
    Gets the filter ID.
    Syntax
    Public ReadOnly Property ID As String
    public string ID {get;}
    Remarks
    The filter id is assigned automatically when the filter definition is constructed
    Example
    Get BuildingSceneLayer Filter ID and Filter
      var filterDefinition = bsl.GetFilter(filterID);
      //or via Linq
      //var filter = bsl.GetFilters().FirstOrDefault(f => f.ID == filterID1);
    Create a Filter using Building Level and Category
      // Note: call within QueuedTask.Run()
        //refer to "Query Building Scene Layer for available Types and Values
        var dict = bsl.GetAvailableFieldsAndValues();
        var categories = dict.SingleOrDefault(kvp => kvp.Key == "Category").Value;
        //get a list of existing floors or "levels"
        var floors = dict.SingleOrDefault(kvp => kvp.Key == "BldgLevel").Value;
        //Make a new filter definition
        var fd = new FilterDefinition()
          Name = "Floor and Category Filter",
          Description = "Example filter",
        //Set up the values for the filter
        var filtervals = new Dictionary<string, List<string>>();
        filtervals.Add("BldgLevel", new List<string>() { floors[0] });
        var category_vals = categories.Where(v => v == "Walls" || v == "Stairs").ToList() ?? new List<string>();
        if (category_vals.Count() > 0)
          filtervals.Add("Category", category_vals);
        //Create a solid block (other option is "Wireframe")
        var fdef = new FilterBlockDefinition()
          FilterBlockMode = Object3DRenderingMode.None,
          Title = "Solid Filter",
          SelectedValues = filtervals//Floor and Category
        //Apply the block
        fd.FilterBlockDefinitions = new List<FilterBlockDefinition>() { fdef };
        //Add the filter definition to the layer
        bsl.UpdateFilter(fd);
        //Set it active. The ID is auto-generated
        bsl.SetActiveFilter(fd.ID);
    Remove BuildingSceneLayer Filter
        //Note: Use HasFilter to check if a given filter id exists in the layer
        if (bsl.HasFilter(filter.ID))
          bsl.RemoveFilter(filter.ID);
        //Or remove all filters
        bsl.RemoveAllFilters();
    Requirements
