//Get the LayerDocument from a lyrx file
var layerDoc = new LayerDocument(@"E:\Data\SDK\Default2DPointSymbols.lyrx");
//Get the CIMLayerDocument from the LayerDocument and use it to create LayerCreationParams
var createParams = new LayerCreationParams(layerDoc.GetCIMLayerDocument());
//Create a FeatureLayer using the LayerCreationParams
//Note: Needs QueuedTask to run
LayerFactory.Instance.CreateLayer<FeatureLayer>(createParams, MapView.Active.Map);
//Note: Call within QueuedTask.Run()
var lyrDocFromLyrxFile = new LayerDocument(@"d:\data\cities.lyrx");
var cimLyrDoc = lyrDocFromLyrxFile.GetCIMLayerDocument();
//modifying its renderer symbol to red
var cimSimpleRenderer = ((CIMFeatureLayer)cimLyrDoc.LayerDefinitions[0]).Renderer as CIMSimpleRenderer;
cimSimpleRenderer?.Symbol.Symbol.SetColor(new CIMRGBColor() { R = 255 });
//optionally save the updates out as a file
lyrDocFromLyrxFile.Save(@"c:\data\cities_red.lyrx");
//get a json representation of the layer document and you want store away...
var aJSONString = lyrDocFromLyrxFile.AsJson();
//... and load it back when needed
lyrDocFromLyrxFile.Load(aJSONString);
//create a layer and add it to a map
var lcp = new LayerCreationParams(cimLyrDoc);
var lyr = LayerFactory.Instance.CreateLayer<FeatureLayer>(lcp, map);
IEnumerable<FeatureLayer> featureLayers = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>()
.Where(l => l.ShapeType == esriGeometryType.esriGeometryPoint);
var layerFile = @"C:\Data\SDK\UniqueValuePointLayer.lyrx";
foreach (var featureLayerToSymbolize in featureLayers)
//Get the Layer Document from the lyrx file
var lyrDocFromLyrxFile = new LayerDocument(layerFile);
//Get the renderer from the layer file
var rendererFromLayerFile = ((CIMFeatureLayer)cimLyrDoc.LayerDefinitions[0]).Renderer as CIMUniqueValueRenderer;
//Apply the renderer to the feature layer
//Note: If working with a raster layer, use the SetColorizer method.
featureLayerToSymbolize?.SetRenderer(rendererFromLayerFile);
LayerDocument layerDocument = new LayerDocument(layer);
//Note: Run within QueuedTask
layerDocument.Save(@"c:\Data\MyLayerDocument.lyrx");
System.Object
ArcGIS.Desktop.Mapping.Document
ArcGIS.Desktop.Mapping.LayerDocument
