ArcGIS.Desktop.Mapping Namespace / MapFactory Class / CanConvertMapFromItem Method
The map item to test
The type to convert the map item to
    CanConvertMapFromItem Method (MapFactory)
    Determine whether the map item can be converted to the specified output type. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public bool CanConvertMapFromItem(
       MapProjectItem mapItem,
       MapConversionType convertTo
    Public Function CanConvertMapFromItem( _
       ByVal mapItem As MapProjectItem, _
       ByVal convertTo As MapConversionType _
    ) As Boolean
    Parameters
    mapItem
    convertTo
    Return Value
    Exceptions
    ExceptionDescription
    Remarks
    The following conversions are supported (the map referenced by the map item is tested):
    o Map -> Base map, Scene (Global), Scene (Local)
    o BaseMap -> Map
    o Scene (Global) -> Map
    o Scene (Local) -> Map
    Specifying an invalid conversion type will return false
    Note: If MapConversionType.SceneGlobal is specified, if the map item's map spatial reference contains a vertical coordinate system, the VCS is checked to see if it is compatible with a global scene. If it is not, the method will also return false
    Requirements
