ArcGIS.Core.Data Namespace / TrackType Enumeration
Example Example
    Specifies whether the tracking data in a dataset is Spatial or Attribute-Only.
    Syntax
    Members
    MemberDescription
    AttributeOnly Tracking data is attribute-only, eg: a water gauge with varying water levels.
    None No tracking data is present.
    Spatial Tracking data is spatial, eg: a moving object.
    Example
    Determine the Stream Layer type
      //spatial or non-spatial?
      if (streamLayer.TrackType == TrackType.AttributeOnly)
        //this is a non-spatial stream layer
      else
        //this must be a spatial stream layer
    Get The Track Type
      var trackType = streamLayer.TrackType;
      switch (trackType)
        //TODO deal with tracktype
        case TrackType.None:
        case TrackType.AttributeOnly:
        case TrackType.Spatial:
          break;
    Set Stream Layer properties via the CIM
      //The layer must be track aware and spatial
      if (streamLayer.TrackType != TrackType.Spatial)
        // not track aware and spatial
      // Note: call within QueuedTask.Run()
        //get the CIM Definition
        var def = streamLayer.GetDefinition() as CIMFeatureLayer;
        //set the number of previous observations,
        def.PreviousObservationsCount = (int)streamLayer.GetExpirationMaxCount() - 1;
        //set show previous observations and track lines to true
        def.ShowPreviousObservations = true;
        def.ShowTracks = true;
        //commit the changes
        streamLayer.SetDefinition(def);
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.Data.TrackType
    Requirements
