ArcGIS.Desktop.Core Namespace / CustomItemBase Class / OnRename Method
The new item name
    OnRename Method
    Override to implement any custom logic for rename of your item
    Syntax
    protected virtual bool OnRename(
       string newName
    Protected Overridable Function OnRename( _
       ByVal newName As String _
    ) As Boolean
    Parameters
    newName
    The new item name
    Return Value
    True if rename is successfull
    Remarks
    If the custom item points to a file on disk, it is the responsibility of the custom item to rename the file accordingly. The item Path should also be updated to point to the renamed file.
    Requirements
