ArcGIS.Desktop.Mapping Namespace / FeatureRendererTarget Enumeration
Example Example
    Specifies a valid list of renderer objects that can exist on a FeatureLayer.
    Syntax
    Members
    MemberDescription
    DefaultThe default renderer.
    PreviousObservationsThe Previous Observations renderer.
    TrackLinesThe Track Lines renderer.
    Example
    Setting a unique value renderer for previous observations
      //The layer must be track aware and spatial
      if (streamLayer.TrackType != TrackType.Spatial)
        // not track aware and spatial
      await QueuedTask.Run(() =>
        //Define unique value classes same as we do for current observations
        //or use "CreateRenderer(...)" to assign them automatically
        CIMUniqueValueClass uvcB727Prev = new CIMUniqueValueClass()
          Values = new CIMUniqueValue[] { new CIMUniqueValue() {
          FieldValues = new string[] { "B727" } } },
          Visible = true,
          Label = "Boeing 727",
          Symbol = SymbolFactory.Instance.ConstructPointSymbol(
          CIMColor.CreateRGBColor(255, 0, 0), 4, SimpleMarkerStyle.Hexagon)
          .MakeSymbolReference()
        CIMUniqueValueClass uvcD9Prev = new CIMUniqueValueClass()
          FieldValues = new string[] { "DC9" } } },
          Visible = true,
          Label = "DC 9",
            CIMColor.CreateRGBColor(0, 255, 0), 4, SimpleMarkerStyle.Hexagon)
        CIMUniqueValueGroup uvGrpPrev = new CIMUniqueValueGroup()
          Classes = new CIMUniqueValueClass[] { uvcB727Prev, uvcD9Prev }
        var UVrndr = new CIMUniqueValueRenderer()
          Fields = new string[] { "ACTYPE" },
          Groups = new CIMUniqueValueGroup[] { uvGrpPrev },
          UseDefaultSymbol = true,
          DefaultLabel = "Others",
          DefaultSymbol = SymbolFactory.Instance.ConstructPointSymbol(
            CIMColor.CreateRGBColor(185, 185, 185), 4, SimpleMarkerStyle.Hexagon)
        streamLayer.SetRenderer(UVrndr, FeatureRendererTarget.PreviousObservations);
    Setting a simple renderer to draw track lines
        //Note: only a simple renderer with solid line symbol is supported for track
        //line renderer
        var trackRenderer = new SimpleRendererDefinition()
          SymbolTemplate = SymbolFactory.Instance.ConstructLineSymbol(
              ColorFactory.Instance.BlueRGB, 2, SimpleLineStyle.Solid)
             streamLayer.CreateRenderer(trackRenderer),
               FeatureRendererTarget.TrackLines);
    Retrieve the previous observation renderer
        var prev_renderer = streamLayer.GetRenderer(
    Retrieve the track lines renderer
        var track_renderer = streamLayer.GetRenderer(
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Desktop.Mapping.FeatureRendererTarget
    Requirements
