ArcGIS.Core.Data.DDL Namespace / SpatialIndexDescription Class / SpatialIndexDescription Constructor / SpatialIndexDescription Constructor(String,FeatureClassDescription)
The name of the index description.
The description object representing the ArcGIS.Core.Data.FeatureClass that will hold the index.
    Creates a description object of the spatial ArcGIS.Core.Data.Index. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    IndexName
    featureClassDescription
    Exceptions
    ExceptionDescription
    The description name cannot be null or empty.
    featureClassDescription cannot be null
    Requirements
    ArcGIS Pro version: 3.4 or higher.
