ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraphPropertyInfo Class / DestinationIDPropertyName Property
Example
    Gets the name of the graph property representing the Destination ID for relationship object types in a KnowledgeGraph.
    Syntax
    Public ReadOnly Property DestinationIDPropertyName As String
    public string DestinationIDPropertyName {get;}
    Example
    Create a new Relationship from Existing Entities 1
      var create_rel = await QueuedTask.Run(() =>
        //Instantiate an operation for the Create
        var edit_op = new EditOperation()
          Name = "Create a new relationship record",
          SelectNewFeatures = true
        //Use datasets or feature layer(s) or standalone table(s)
        //Get a reference to the KnowledgeGraph
        //var kg = ... ;
        //We will use a relate called 'HasEmployee' to relate an Organization w/ a Person
        //Use either tables or map members to get the rows to be related...
        var org_fc = kg.OpenDataset<FeatureClass>("Organization");
        var person_tbl = kg.OpenDataset<Table>("Person");
        //Get the relationship dataset
        //We can use either a table or standalone table
        var emp_tbl = kg.OpenDataset<Table>("HasEmployee");
        //we need the names of the origin and destination relationship properties
        var kg_prop_info = kg.GetPropertyNameInfo();
        //Arbitrarily use the first record from the two entity datasets "to be" related
        //Entities are always related by Global ID. Origin to Destination specifies the
        //direction (of the relate).
        //Populate the attributes for the relationship
        var attribs = new Dictionary<string, object>();
        using (var rc = org_fc.Search())
          if (rc.MoveNext())
            //Use the KnowledgeGraphPropertyInfo to avoid hardcoding...
            attribs[kg_prop_info.OriginIDPropertyName] = rc.Current.GetGlobalID();
        using (var rc = person_tbl.Search())
          if (rc.MoveNext())
            attribs[kg_prop_info.DestinationIDPropertyName] = rc.Current.GetGlobalID();
        //Add any extra attribute information for the relation as needed
        attribs["StartDate"] = new DateTimeOffset(DateTime.Now);
        //Add a create for the relationship to the operation
        edit_op.Create(emp_tbl, attribs);
        //Do the create
        return edit_op.Execute();
    Create a new Relationship and New Entities 1
      var mv = MapView.Active;
      var create_rel1 = await QueuedTask.Run(() =>
        //This example uses a chained edit operation
          Name = "Create entities and a relationship",
        //We are just going to use the GDB objects in this one but
        //we could equally use feature layers/standalone tables
        //using Feature Class/Tables (works within Investigation or map)
        //Relationship table
        //New Organization
        attribs["Name"] = "Acme Ltd.";
        attribs["Description"] = "Specializes in household items";
        attribs["SHAPE"] = mv.Extent.Center;//whatever is its location
        //Add it to the operation - we need the rowtoken
        var rowtoken = edit_op.Create(org_fc, attribs);
        attribs.Clear();//we are going to re-use the dictionary
        //New Person
        attribs["Name"] = "Bob";
        attribs["Age"] = "41";
        attribs["Skills"] = "Plumbing, Framing, Flooring";
        var rowtoken2 = edit_op.Create(person_tbl, attribs);
        attribs.Clear();
        //At this point we must execute the create of the entities
        if (edit_op.Execute())
          //if we are here, the create of the entities was successful
          //Next, "chain" a second create for the relationship - this ensures that
          //Both creates (entities _and_ relation) will be -undone- together if needed
          //....in other words they will behave as if they are a -single- transaction
          var edit_op_rel = edit_op.CreateChainedOperation();
          //we need the names of the origin and destination relation properties
          //use the row tokens we held on to from the entity creates
          attribs[kg_prop_info.OriginIDPropertyName] = rowtoken.GlobalID;
          attribs[kg_prop_info.DestinationIDPropertyName] = rowtoken2.GlobalID;
          //Do the create of the relate
          edit_op_rel.Create(emp_tbl, attribs);
          return edit_op_rel.Execute();
        return false;//Create of entities failed
    Create a Document Record 1
      var ok = await QueuedTask.Run(() =>
        using (var kg_for_doc = kgLayer.GetDatastore())
            Name = "Create Document Example",
          var doc_entity_name = GetDocumentTypeName(kg_for_doc.GetDataModel());
          if (string.IsNullOrEmpty(doc_entity_name))
            return false;
          var hasdoc_rel_name = GetHasDocumentTypeName(kg_for_doc.GetDataModel());
          if (string.IsNullOrEmpty(hasdoc_rel_name))
            return false;
          //Document can also be FeatureClass
          var doc_tbl = kg_for_doc.OpenDataset<Table>(doc_entity_name);
          var doc_rel_tbl = kg_for_doc.OpenDataset<Table>(hasdoc_rel_name);
          //This is the document to be added...file, image, resource, etc.
          var doc_url = @"E:\Data\Temp\HelloWorld.txt";
          var text = System.IO.File.ReadAllText(url);
          //Set document properties
          attribs["contentType"] = @"text/plain";
          attribs["name"] = System.IO.Path.GetFileName(url);
          attribs["url"] = doc_url;
          //Add geometry if relevant
          //attribs["Shape"] = doc_location;
          //optional
          attribs["fileExtension"] = System.IO.Path.GetExtension(doc_url);
          attribs["text"] = System.IO.File.ReadAllText(doc_url);
          //optional and arbitrary - your choice
          attribs["title"] = System.IO.Path.GetFileNameWithoutExtension(doc_url);
          attribs["keywords"] = @"text,file,example";
          attribs["metadata"] = "";
          //Specify any additional custom attributes added to the document
          //schema by the user as needed....
          //attribs["custom_attrib"] = "Foo";
          //attribs["custom_attrib2"] = "Bar";
          //Get the entity whose document this is...
          var org_fc = kg_for_doc.OpenDataset<FeatureClass>("Organization");
          var qf = new ArcGIS.Core.Data.QueryFilter()
            WhereClause = "name = 'Acme'",
            SubFields = "*"
          var origin_org_id = Guid.Empty;
          using (var rc = org_fc.Search(qf))
            if (!rc.MoveNext())
              return false;
            origin_org_id = rc.Current.GetGlobalID();//For the relate
          //Create the document row/feature
          var rowtoken = edit_op.Create(doc_tbl, attribs);
            //Create the relationship row
            attribs.Clear();
            var kg_prop_info = kg_for_doc.GetPropertyNameInfo();
            //Specify the origin entity (i.e. the document 'owner') and
            //the document being related to (i.e. the document 'itself')
            attribs[kg_prop_info.OriginIDPropertyName] = origin_org_id;//entity
            attribs[kg_prop_info.DestinationIDPropertyName] = rowtoken.GlobalID;//document
            //Specify any custom attributes added to the has document
            //"Chain" a second create for the relationship - this ensures that
            //Both creates (doc _and_ "has doc" relation) will be -undone- together if needed
            edit_op_rel.Create(doc_rel_tbl, attribs);
          return false;
    string GetDocumentTypeName(KnowledgeGraphDataModel kg_dm)
      var entity_types = kg_dm.GetEntityTypes();
      foreach (var entity_type in entity_types)
        var role = entity_type.Value.GetRole();
        if (role == KnowledgeGraphNamedObjectTypeRole.Document)
          return entity_type.Value.GetName();
      return "";
    string GetHasDocumentTypeName(KnowledgeGraphDataModel kg_dm)
      var rel_types = kg_dm.GetRelationshipTypes();
      foreach (var rel_type in rel_types)
        var role = rel_type.Value.GetRole();
          return rel_type.Value.GetName();
      return "";
    Requirements
    ArcGIS Pro version: 3.4 or higher.
