ArcGIS.Core.Geometry Namespace / BasicMaterial Class / BasicMaterial Constructor / BasicMaterial Constructor(BasicMaterial)
The material used for construction.
Example
    Creates a deep copy of the BasicMaterial.
    Syntax
    Public Function New( _
       ByVal other As BasicMaterial _
    public BasicMaterial(
       BasicMaterial other
    Parameters
    other
    Remarks
    The TextureResource it contains is deep copied. The copied material does not share the texture resource with the original.
    Example
    Construct Multipatch via MultipatchBuilderEx
      var coords_face1 = new List<Coordinate3D>()
      new Coordinate3D(12.495461061000071,41.902603910000039,62.552700000000186),
      new Coordinate3D(12.495461061000071,41.902603910000039,59.504700000004959),
      new Coordinate3D(12.495461061000071,41.902576344000067,59.504700000004959),
      new Coordinate3D(12.495461061000071,41.902576344000067,62.552700000000186),
      var coords_face2 = new List<Coordinate3D>()
      new Coordinate3D(12.495461061000071, 41.902576344000067, 62.552700000000186),
      new Coordinate3D(12.495461061000071, 41.902576344000067, 59.504700000004959),
      new Coordinate3D(12.495488442000067, 41.902576344000067, 59.504700000004959),
      new Coordinate3D(12.495488442000067, 41.902576344000067, 62.552700000000186),
      var coords_face3 = new List<Coordinate3D>()
      new Coordinate3D(12.495488442000067, 41.902603910000039, 59.504700000004959),
      new Coordinate3D(12.495488442000067, 41.902603910000039, 62.552700000000186),
      var coords_face4 = new List<Coordinate3D>()
      new Coordinate3D(12.495461061000071, 41.902603910000039, 59.504700000004959),
      var coords_face5 = new List<Coordinate3D>()
      new Coordinate3D(12.495461061000071, 41.902603910000039, 62.552700000000186),
      var coords_face6 = new List<Coordinate3D>()
      // materials
      var materialRed = new BasicMaterial();
      materialRed.Color = System.Windows.Media.Colors.Red;
      var materialTransparent = new BasicMaterial();
      materialTransparent.Color = System.Windows.Media.Colors.White;
      materialTransparent.TransparencyPercent = 80;
      var blueTransparent = new BasicMaterial(materialTransparent);
      blueTransparent.Color = System.Windows.Media.Colors.SkyBlue;
      // create a list of patch objects
      var patchesList = new List<Patch>();
      // create the multipatchBuilderEx object
      var mpb = new ArcGIS.Core.Geometry.MultipatchBuilderEx();
      // make each patch using the appropriate coordinates and add to the patch list
      var patch = mpb.MakePatch(PatchType.Triangles);
      patch.Coords = coords_face1;
      patchesList.Add(patch);
      patch.Coords = coords_face2;
      patch.Coords = coords_face3;
      patch.Coords = coords_face4;
      patch.Coords = coords_face5;
      patch.Coords = coords_face6;
      patchesList[0].Material = materialRed;
      patchesList[1].Material = materialTransparent;
      patchesList[2].Material = materialRed;
      patchesList[3].Material = materialRed;
      patchesList[4].Material = materialRed;
      patchesList[5].Material = blueTransparent;
      // assign the patches to the multipatchBuilder
      mpb.Patches = patchesList;
      // check which patches currently contain the material
      var red = mpb.QueryPatchIndicesWithMaterial(materialRed);
      //   red should be [0, 2, 3, 4]
      // call ToGeometry to get the multipatch
      multipatch = mpb.ToGeometry() as Multipatch;
    Create BasicMaterial
      // Create BasicMaterial with default values
      BasicMaterial material = new BasicMaterial();
      System.Windows.Media.Color color = material.Color;         // color = Colors.Black
      System.Windows.Media.Color edgeColor = material.EdgeColor; // edgeColor = Colors.Black
      int edgeWidth = material.EdgeWidth;                        // edgeWidth = 0
      int transparency = material.TransparencyPercent;           // transparency = 0
      int shininess = material.Shininess;                        // shininess = 0
      bool cullBackFace = material.IsCullBackFace;               // cullBackFace = false
      // Modify the properties
      material.Color = System.Windows.Media.Colors.Red;
      material.EdgeColor = System.Windows.Media.Colors.Blue;
      material.EdgeWidth = 10;
      material.TransparencyPercent = 50;
      material.Shininess = 25;
      material.IsCullBackFace = true;
    Requirements
