var coords_face1 = new List<Coordinate3D>()
new Coordinate3D(12.495461061000071,41.902603910000039,62.552700000000186),
new Coordinate3D(12.495461061000071,41.902603910000039,59.504700000004959),
new Coordinate3D(12.495461061000071,41.902576344000067,59.504700000004959),
new Coordinate3D(12.495461061000071,41.902576344000067,62.552700000000186),
var coords_face2 = new List<Coordinate3D>()
new Coordinate3D(12.495461061000071, 41.902576344000067, 62.552700000000186),
new Coordinate3D(12.495461061000071, 41.902576344000067, 59.504700000004959),
new Coordinate3D(12.495488442000067, 41.902576344000067, 59.504700000004959),
new Coordinate3D(12.495488442000067, 41.902576344000067, 62.552700000000186),
var coords_face3 = new List<Coordinate3D>()
new Coordinate3D(12.495488442000067, 41.902603910000039, 59.504700000004959),
new Coordinate3D(12.495488442000067, 41.902603910000039, 62.552700000000186),
var coords_face4 = new List<Coordinate3D>()
new Coordinate3D(12.495461061000071, 41.902603910000039, 59.504700000004959),
var coords_face5 = new List<Coordinate3D>()
new Coordinate3D(12.495461061000071, 41.902603910000039, 62.552700000000186),
var coords_face6 = new List<Coordinate3D>()
// materials
var materialRed = new BasicMaterial();
materialRed.Color = System.Windows.Media.Colors.Red;
var materialTransparent = new BasicMaterial();
materialTransparent.Color = System.Windows.Media.Colors.White;
materialTransparent.TransparencyPercent = 80;
var blueTransparent = new BasicMaterial(materialTransparent);
blueTransparent.Color = System.Windows.Media.Colors.SkyBlue;
// create a list of patch objects
var patchesList = new List<Patch>();
// create the multipatchBuilderEx object
var mpb = new ArcGIS.Core.Geometry.MultipatchBuilderEx();
// make each patch using the appropriate coordinates and add to the patch list
var patch = mpb.MakePatch(PatchType.Triangles);
patch.Coords = coords_face1;
patchesList.Add(patch);
patch.Coords = coords_face2;
patch.Coords = coords_face3;
patch.Coords = coords_face4;
patch.Coords = coords_face5;
patch.Coords = coords_face6;
patchesList[0].Material = materialRed;
patchesList[1].Material = materialTransparent;
patchesList[2].Material = materialRed;
patchesList[3].Material = materialRed;
patchesList[4].Material = materialRed;
patchesList[5].Material = blueTransparent;
// assign the patches to the multipatchBuilder
mpb.Patches = patchesList;
// check which patches currently contain the material
var red = mpb.QueryPatchIndicesWithMaterial(materialRed);
// red should be [0, 2, 3, 4]
// call ToGeometry to get the multipatch
multipatch = mpb.ToGeometry() as Multipatch;
var sr = MapView.Active.Map.SpatialReference;
var extent = MapView.Active.Extent;
var center = extent.Center;
var centerZ = MapPointBuilderEx.CreateMapPoint(center.X, center.Y, 500, sr);
// cube
multipatch = ArcGIS.Core.Geometry.MultipatchBuilderEx.CreateMultipatch(MultipatchConstructType.Cube, centerZ, 200, sr);
// tetrahedron
multipatch = ArcGIS.Core.Geometry.MultipatchBuilderEx.CreateMultipatch(MultipatchConstructType.Tetrahedron, centerZ, 200, sr);
// diamond
multipatch = ArcGIS.Core.Geometry.MultipatchBuilderEx.CreateMultipatch(MultipatchConstructType.Diamond, centerZ, 200, sr);
// hexagon
multipatch = ArcGIS.Core.Geometry.MultipatchBuilderEx.CreateMultipatch(MultipatchConstructType.Hexagon, centerZ, 200, sr);
// sphere frame
multipatch = ArcGIS.Core.Geometry.MultipatchBuilderEx.CreateMultipatch(MultipatchConstructType.SphereFrame, centerZ, 200, 0.8, sr);
// sphere
multipatch = ArcGIS.Core.Geometry.MultipatchBuilderEx.CreateMultipatch(MultipatchConstructType.Sphere, centerZ, 200, 0.8, sr);
// cylinder
multipatch = ArcGIS.Core.Geometry.MultipatchBuilderEx.CreateMultipatch(MultipatchConstructType.Cylinder, centerZ, 200, 0.8, sr);
// cone
multipatch = ArcGIS.Core.Geometry.MultipatchBuilderEx.CreateMultipatch(MultipatchConstructType.Cone, centerZ, 200, 0.8, sr);
// use the builder to add materials or textures
var builder = new ArcGIS.Core.Geometry.MultipatchBuilderEx(multipatch);
// - create a cone with a material
builder = new MultipatchBuilderEx(MultipatchConstructType.Cone, centerZ, 200, 0.8, sr);
BasicMaterial faceMaterial = new BasicMaterial();
faceMaterial.Color = System.Windows.Media.Color.FromRgb(255, 0, 0);
faceMaterial.Shininess = 150;
faceMaterial.TransparencyPercent = 50;
faceMaterial.EdgeWidth = 20;
foreach (var patch in builder.Patches)
patch.Material = faceMaterial;
multipatch = builder.ToGeometry() as Multipatch;
// Create BasicMaterial with default values
BasicMaterial material = new BasicMaterial();
System.Windows.Media.Color color = material.Color; // color = Colors.Black
System.Windows.Media.Color edgeColor = material.EdgeColor; // edgeColor = Colors.Black
int edgeWidth = material.EdgeWidth; // edgeWidth = 0
int transparency = material.TransparencyPercent; // transparency = 0
int shininess = material.Shininess; // shininess = 0
bool cullBackFace = material.IsCullBackFace; // cullBackFace = false
// Modify the properties
material.Color = System.Windows.Media.Colors.Red;
material.EdgeColor = System.Windows.Media.Colors.Blue;
material.EdgeWidth = 10;
material.TransparencyPercent = 50;
material.Shininess = 25;
material.IsCullBackFace = true;
