ArcGIS.Core.Geometry Namespace / GeometryEngine Class / SplitAtPoint Method
The multipart along which the point will be inserted.
The point to be inserted.
Determines if the output point will be located on the curve. If true and the splitPoint is not already on the curve then the point is projected onto the curve.
Determines if parts are to be created. MUST be false for polygons. For polylines, if true, the part on which the new split point falls is split into two parts with the newly added vertex serving as the end of the first part and the beginning of the second.
Determines if a split occurred.
Part index that has the point added. If splitOccurred is false, this value should be ignored.
Segment index that has the point added. The segment may be a newly created segment. If splitOccurred is false, this value should be ignored.
Example
    SplitAtPoint Method (GeometryEngine)
    Adds a new vertex along the multipoint at the specified input point or the projection onto the multipart of the specified input point.
    Syntax
    Public Function SplitAtPoint( _
       ByVal multipart As Multipart, _
       ByVal splitPoint As MapPoint, _
       ByVal projectOnto As Boolean, _
       ByVal createPart As Boolean, _
       ByRef splitOccurred As Boolean, _
       ByRef partIndex As Integer, _
       ByRef segmentIndex As Integer _
    ) As Multipart
    Parameters
    multipart
    splitPoint
    projectOnto
    createPart
    splitOccurred
    partIndex
    segmentIndex
    Return Value
    A geometry with the new vertex added. If no split occurred, then the original multipart is returned.
    Exceptions
    ExceptionDescription
    Either multipartor splitPointor both are null.
    createPart must be false for polygons.
    Incompatible spatial references between the input geometries.
    The input multipart is empty.
    The input point is empty, or the specified splitting distance is not included in the curve to be split.
    Example
    Split multipart at point
      // define a polyline
      MapPoint startPointZ = MapPointBuilderEx.CreateMapPoint(1, 1, 5);
      MapPoint endPointZ = MapPointBuilderEx.CreateMapPoint(20, 1, 5);
      Polyline polylineZ = PolylineBuilderEx.CreatePolyline([startPointZ, endPointZ]);
      // define a split point
      MapPoint splitPointAboveLine = MapPointBuilderEx.CreateMapPoint(10, 10, 10);
      // split the polyline at the point. Don't project the split point onto the line, don't create a new part
      var splitPolyline = GeometryEngine.Instance.SplitAtPoint(polylineZ, splitPointAboveLine, false, false, out bool splitOccurred, out int partIndex, out int segmentIndex);
      // splitOccurred = true
      // partIndex = 0
      // segmentIndex = 1
      // splitPolyline.PointCount = 3
      // splitPolyline.PartCount = 1
      // splitPolyline coordinates are (1, 1, 5), (10, 10, 10), (20, 1, 5)
      // split the polyline at the point.  dont project the split point onto the line, do create a new part
      splitPolyline = GeometryEngine.Instance.SplitAtPoint(polylineZ, splitPointAboveLine, false, false, out splitOccurred, out partIndex, out segmentIndex);
      // partIndex = 1
      // segmentIndex = 0
      // splitPolyline.PointCount = 4
      // splitPolyline.PartCount = 2
      // splitPolyline first part coordinates are (1, 1, 5), (10, 10, 10)
      // splitPolyline second part coordinates are (10, 10, 10), (20, 1, 5)
      // split the polyline at the point.  do project the split point onto the line, don't create a new part
      // partIndex = 0
      // segmentIndex = 1
      // splitPolyline coordinates are (1, 1, 5), (10, 10, 5), (20, 1, 5)
      // split the polyline at the point.  do project the split point onto the line, do create a new part
      // partIndex = 1
      // segmentIndex = 0
      // splitPolyline first part coordinates are (1, 1, 5), (10, 10, 5)
      // splitPolyline second part coordinates are (10, 10, 5), (20, 1, 5)
      // try to split with a point that won't split the line  - pt extends beyond the line
      var pointAfterLine = MapPointBuilderEx.CreateMapPoint(50, 1, 10);
      splitPolyline = GeometryEngine.Instance.SplitAtPoint(polylineZ, pointAfterLine, false, false, out splitOccurred, out partIndex, out segmentIndex);
      // splitOccurred = false
      // ignore partIndex, sgementIndex
      // splitPolyline is the same as polylineZ
      ///  multipart polygon
      List<Coordinate3D> coordsZ =
        new Coordinate3D(10,10,5),
      new Coordinate3D(10,20,5),
      new Coordinate3D(20,20,5),
      new Coordinate3D(20,10,5)
      List<Coordinate3D> coordsZ_2ndPart =
        new Coordinate3D(30,20,10),
      new Coordinate3D(30,30,10),
      new Coordinate3D(35,28,10),
      new Coordinate3D(40,30,10),
      new Coordinate3D(40,20,10)
      var builder = new PolygonBuilderEx
        HasZ = true
      builder.AddPart(coordsZ);
      builder.AddPart(coordsZ_2ndPart);
      Polygon multipart = builder.ToGeometry();
      // pointA is closer to the first part of the multipart - the split occurs in the first part
      var pointA = MapPointBuilderEx.CreateMapPoint(22, 18, 7);
      var splitPolygon = GeometryEngine.Instance.SplitAtPoint(multipart, pointA, false, false, out splitOccurred, out partIndex, out segmentIndex);
      // splitPolygon.PointCount = 12
      // splitPolygon.PartCount = 2
      // splitPolygon first part coordinates  (10, 10, 5), (10, 20, 5), (20, 20, 5), (22, 18, 7), (20, 10, 5), (10, 10, 5)
      // pointB is midPoint between the 2 parts - no split will occur
      var pointB = MapPointBuilderEx.CreateMapPoint(25, 20, 7);
      splitPolygon = GeometryEngine.Instance.SplitAtPoint(multipart, pointB, true, false, out splitOccurred, out partIndex, out segmentIndex);
    Requirements
