ArcGIS.Core.Geometry Namespace / JPEGTexture Class / ColumnCount Property
Example
    ColumnCount Property (JPEGTexture)
    Gets the width of the image in pixels.
    Syntax
    Public Overrides ReadOnly Property ColumnCount As Integer
    public override int ColumnCount {get;}
    Example
    Create BasicMaterial with JPEG texture
      // read the jpeg into a buffer
      //At 3.0 you need https://www.nuget.org/packages/Microsoft.Windows.Compatibility
      //System.Drawing
      System.Drawing.Image image = System.Drawing.Image.FromFile(@"C:\temp\myImageFile.jpg");
      MemoryStream memoryStream = new MemoryStream();
      System.Drawing.Imaging.ImageFormat format = System.Drawing.Imaging.ImageFormat.Jpeg;
      image.Save(memoryStream, format);
      byte[] imageBuffer = memoryStream.ToArray();
      var jpgTexture = new JPEGTexture(imageBuffer);
      // texture properties
      int bpp = jpgTexture.BytesPerPixel;
      int columnCount = jpgTexture.ColumnCount;
      int rowCount = jpgTexture.RowCount;
      // build the textureResource and the material
      BasicMaterial material = new BasicMaterial();
      material.TextureResource = new TextureResource(jpgTexture);
    Requirements
