ArcGIS.Core.Geometry Namespace / MultipatchBuilderEx Class / GetPatchPointCount Method
The patch index. Must be in the range [0, Patches.Count - 1] inclusive.
Example
    GetPatchPointCount Method (MultipatchBuilderEx)
    A convenience method to return the number of vertices in the specified Patch.
    Syntax
    public int GetPatchPointCount(
       int patchIndex
    Public Function GetPatchPointCount( _
       ByVal patchIndex As Integer _
    ) As Integer
    Parameters
    patchIndex
    Return Value
    Returns the value of Patches[patchIndex].Coords.Count
    Example
    Construct Multipatch from another Multipatch
      TextureResource brickTextureResource = null;
      BasicMaterial brickMaterialTexture = new BasicMaterial();
      var coords = new List<Coordinate3D>();
      // create the multipatchBuilderEx object
      var builder = new ArcGIS.Core.Geometry.MultipatchBuilderEx(multipatch);
      // check some properties
      bool hasM = builder.HasM;
      bool hasZ = builder.HasZ;
      bool hasID = builder.HasID;
      bool isEmpty = builder.IsEmpty;
      bool hasNormals = builder.HasNormals;
      var patches = builder.Patches;
      int patchCount = patches.Count;
      // if there's some patches
      if (patchCount > 0)
        int pointCount = builder.GetPatchPointCount(0);
        // replace the first point in the first patch
        if (pointCount > 0)
          // get the first point
          var pt = builder.GetPoint(0, 0);
          builder.SetPoint(0, 0, mapPoint);
        // check which patches currently contain the texture
        var texture = builder.QueryPatchIndicesWithTexture(brickTextureResource);
        // assign a texture material
        patches[0].Material = brickMaterialTexture;
      // update the builder for M awareness
      builder.HasM = true;
      // synchronize the patch attributes to match the builder attributes
      //   in this instance because we just set HasM to true on the builder, each patch will now get a default M value for it's set of coordinates
      builder.SynchronizeAttributeAwareness();
      // call ToGeometry to get the multipatch
      multipatch = builder.ToGeometry() as Multipatch;
      // multipatch.HasM will be true
    Requirements
