ArcGIS.Core.Geometry Namespace / MultipatchBuilderEx Class / RemovePoints Method
The index of the patch from which points are removed. Must be in the range [0, Patches.Count - 1] inclusive.
The index from which the points are removed. Must be in the range [0, Patch.Coords.Count - 1] inclusive.
The index up to which the points are removed. Must be in the range [fromIndex, Patch.Coords.Count - 2] inclusive. The toIndex index is excluded from the indices that are removed. For example, if from = 3, to = 7, then the points at indices 3, 4, 5, and 6 will be removed.
    RemovePoints Method (MultipatchBuilderEx)
    A convenience method to remove points from the specified Patch
    Syntax
    public void RemovePoints(
       int patchIndex,
       int fromIndex,
       int toIndex
    Public Sub RemovePoints( _
       ByVal patchIndex As Integer, _
       ByVal fromIndex As Integer, _
       ByVal toIndex As Integer _
    Parameters
    patchIndex
    fromIndex
    toIndex
    Exceptions
    ExceptionDescription
    The fromIndex parameter is less than zero or greater than or equal to the patch point count.
    The toIndex parameter is less than the fromIndex parameter or greater than the patch point count.
    Remarks
    If this patch has attributes Ms, IDs, Normals, or TextureCoords2D then the attributes will be removed also.
    Requirements
