ArcGIS.Core.Geometry Namespace / Patch Class / AddPoint Method
The point to add.
    AddPoint Method (Patch)
    Adds a point to the patch.
    Syntax
    public void AddPoint(
       MapPoint point
    Public Sub AddPoint( _
       ByVal point As MapPoint _
    Parameters
    point
    The point to add.
    Exceptions
    ExceptionDescription
    The point is null or empty.
    Remarks
    If this patch has attributes Ms or IDs, then the attributes will be added also. M and ID will be taken from the point if it has them. Otherwise, default values will be added. Similarly, if this patch has attributes TextureCoords2D or Normals, then default values will be added. The default value is (0, 0) for 2D texture coordinates and (0, 0, 1) for normals.
    Requirements
