ArcGIS.Core.Geometry Namespace / Patch Class / RemovePoints Method
The index from which the points are removed. Must be in the range [0, Coords.Count - 1] inclusive.
The index up to which the points are removed. Must be in the range [fromIndex, Coords.Count - 1] inclusive. The toIndex index is excluded from the indices that are removed. For example, if from = 3, to = 7, then the points at indices 3, 4, 5, and 6 will be removed.
    RemovePoints Method (Patch)
    Removes a range of points.
    Syntax
    public void RemovePoints(
       int fromIndex,
       int toIndex
    Public Sub RemovePoints( _
       ByVal fromIndex As Integer, _
       ByVal toIndex As Integer _
    Parameters
    fromIndex
    toIndex
    Exceptions
    ExceptionDescription
    fromIndex is less than zero or greater than or equal to Coords.Count.
    toIndex is less than fromIndex or greater than Coords.Count.
    Remarks
    If this patch has attributes Ms, IDs, Normals, or TextureCoords2D then the attributes will be removed also.
    Requirements
