ArcGIS.Core.Geometry Namespace / Patch Class / SynchronizeAttributeAwarenessWithBuilder Method
The builder with which to synchronize attributes.
    Ensures this Patch has the same attributes as the input MultipatchBuilderEx.
    Syntax
    public bool SynchronizeAttributeAwarenessWithBuilder(
       MultipatchBuilderEx multipatchBuilder
    Public Function SynchronizeAttributeAwarenessWithBuilder( _
       ByVal multipatchBuilder As MultipatchBuilderEx _
    ) As Boolean
    Parameters
    multipatchBuilder
    Return Value
    Returns true if the patches have been changed and false otherwise.
    Remarks
    The method will allocate or remove any attribute (Ms, IDs, Normals) to match the state of HasM, HasID, and HasNormals. It will also adjust the size of the attribute arrays to match the size of the Coords. It will use default values to fill the missing elements in the attribute arrays.
    Requirements
