ArcGIS.Core.Geometry Namespace / UncompressedTexture Class / UncompressedTexture Constructor / UncompressedTexture Constructor(Byte[],Int32,Int32,Byte)
The row-major image buffer. Each bpp bytes represent one pixel.
The number of columns in the image (width of the image).
The number of rows in the image (height of the image).
The number of bytes per one pixel. Should be between 1 and 4.
    Initializes a new instance of the UncompressedTexture class from given data.
    Syntax
    public UncompressedTexture(
       byte[] buffer,
       int columns,
       int rows,
       byte bpp
    Public Function New( _
       ByVal buffer() As Byte, _
       ByVal columns As Integer, _
       ByVal rows As Integer, _
       ByVal bpp As Byte _
    Parameters
    buffer
    columns
    rows
    bpp
    Requirements
