ArcGIS.Desktop.Mapping Namespace / MappingExtensions Class / AddOverlay Method / AddOverlay(MapView,Geometry,CIMSymbolReference,Double) Method
The view to add the overlay.
The geometry of the overlay.
The symbol to use for the overlay.
Map reference scale or -1
Example
    Add an overlay graphic to the map view.
    Syntax
    Public Overloads Shared Function AddOverlay( _
       ByVal mapView As MapView, _
       ByVal geometry As Geometry, _
       Optional ByVal symbol As CIMSymbolReference, _
       Optional ByVal referenceScale As Double _
    ) As IDisposable
    Parameters
    mapView
    geometry
    symbol
    referenceScale
    Return Value
    An object that when disposed will remove the overlay.
    Remarks
    When the referenceScale is not equal to -1, the overlay will be created in real world units relative to the provided map reference scale (referenceScale). Otherwise, the overlay will be created in units of points. This is only supported in 2D.
    Example
    Graphic Overlay
      // get the current MapView and point
      var myextent = mapView.Extent;
      var point = myextent.Center;
      IDisposable _graphic = null;
      // add point graphic to the overlay at the center of the mapView
      // Note: Needs QueuedTask to run
      _graphic = mapView.AddOverlay(point,
          SymbolFactory.Instance.ConstructPointSymbol(
                  ColorFactory.Instance.RedRGB, 30.0, SimpleMarkerStyle.Star).MakeSymbolReference());
      // update the overlay with new point graphic symbol
      MessageBox.Show("Now to update the overlay...");
        mapView.UpdateOverlay(_graphic, point, SymbolFactory.Instance.ConstructPointSymbol(
                                      ColorFactory.Instance.BlueRGB, 20.0, SimpleMarkerStyle.Circle).MakeSymbolReference());
      // clear the overlay display by disposing of the graphic
      MessageBox.Show("Now to clear the overlay...");
      _graphic.Dispose();
    Requirements
