ArcGIS.Desktop.Mapping Namespace / AIXFormat Class / ImageCompressionQuality Property
    ImageCompressionQuality Property (AIXFormat)
    This value (0–100) controls the amount of compression applied to the output image. With a JPEG image, quality is adversely affected the more compression is applied. A higher quality (highest = 100) setting will produce sharper images and larger file sizes. A lower quality setting will produce more image artifacts and smaller files.
    Syntax
    public int ImageCompressionQuality {get; set;}
    Public Property ImageCompressionQuality As Integer
    Remarks
    The default value is 80.
    Requirements
