ArcGIS.Desktop.Mapping Namespace / PopupDefinition Class / Append Property
Example
    Append Property
    Gets or sets whether content already in the dockable window is kept or cleared. Only used when dockable is true.
    Syntax
    public bool Append {get; set;}
    Public Property Append As Boolean
    Example
    Show a pop-up for a feature using pop-up window properties
      if (mapView == null)
        return;
      // Sample code: https://github.com/ArcGIS/arcgis-pro-sdk-community-samples/blob/master/Map-Exploration/CustomIdentify/CustomIdentify.cs
      var topLeftCornerPoint = new System.Windows.Point(200, 200);
      var popupDef = new PopupDefinition()
        Append = true,      // if true new record is appended to existing (if any)
        Dockable = true,    // if true popup is dockable - if false Append is not applicable
        Position = topLeftCornerPoint,  // Position of top left corner of the popup (in pixels)
        Size = new System.Windows.Size(200, 400)    // size of the popup (in pixels)
      mapView.ShowPopup(mapMember, objectID, popupDef);
    Show a custom pop-up using pop-up window properties
        return;
      //Create custom popup content
      List<PopupContent> popups =
          new("<b>This text is bold.</b>", "Custom tooltip from HTML string"),
              new(new Uri("https://www.esri.com/"), "Custom tooltip from Uri")
      // Sample code: https://github.com/ArcGIS/arcgis-pro-sdk-community-samples/blob/master/Framework/DynamicMenu/DynamicFeatureSelectionMenu.cs
      mapView.ShowCustomPopup(popups, null, true, popupDef);
    Requirements
